Does a water heater tempering valve negate the need for point of use thermostatic mixing valves?
WARNING
WATTS HOT WATER EXTENDER TEMPERING VALVES CANNOT
BE USED FOR TEMPERING WATER TEMPERATURE AT FIXTURES.
SEVERE BODILY INJURY (i.e., SCALDING OR CHILLING)
AND/OR DEATH MAY RESULT DEPENDING UPON SYSTEM
WATER PRESSURE CHANGES AND/OR SUPPLY WATER TEMPERATURE
CHANGES. A.S.S.E. STANDARD 1016 LISTED
DEVICES SUCH AS WATTS MODELS L111 OR MMV SHOULD
BE USED AT FIXTURES TO PREVENT POSSIBLE INJURY.
The WATTS hot water tempering valves are designed to be installed
at or near the boiler or hot water heater. They are not designed
to compensate for system pressure and/or temperature
fluctuations and should not be used where devices tested to
A.S.S.E. standard 1016 are required. These WATTS valves should
never be used to provide "anti-scald" or "anti-chill" service.
