And also not sure about your jurisdiction but in mine you aren't allowed to put a 90 right off the draft hood, should go up about a ft first. But that may depend on area
And it sounds like a TCO switch might be shot on your HWT. If it has one then that could be the problem. That's usually due to 3" venting on a hot water heater instead of 4". Plus those extra bends can't be helping
Yeah definitely doesn't look like it's up to code. Too many bends will create more restriction of flow for the flue gases. The more vertical the better negative draft you will have which is what you want. They kinda seem to go up at an angle instead of straight up then over to your common vent.
It is against code to use ANY tape on the Vent piping, you need to use 3 screws and NO tape. Also the acidity from the boiler discharge will destroy the mortar in the joints holding the chimny together in no time. to do this Correctlly you need to have a liner pulled in the chimney but you STILL wouldnt be able to have those 2 appliances vented that close to each other and in that mannor.
also you cant Toss a 90' bend right off of the top of the flue collar.
AND I can see that you love sharkbite ( those shark flex connectors arnt cheap either ) but you are asking for many problems looking at the pics in general. At least Dont have the flex connector touching the vent ( 6" minimum distance between single wall and objects.
Not trying to be a dick, but YOU need a professional.
