westerberg19390
Problem started when we noticed tap water was extremely hot. Shortly after we stopped getting hot water. I removed the cover of upper access panel and noticed that the upper thermostat's thermal fuse had been tripped. Removing cover of lower access panel showed the coating had melted on the wire connecting the thermostat to the heating element. Is the solution simply a matter of replacing the lower thermostat, or is there a deeper problem ?
