Washer drain p trap, and cleanout critique - Pic included
skobydog
Jun 20, 2015
I had a design that I was going to do but realized that this set up (pic) will work better to line up my current vent, stand pipe, etc. I'm not sure if the clean out is ok this way. I could also reverse the vent and clean out if that helps.
I'm in Massachusetts. Anyway, does this setup look ok? Thanks
Vent or stand pipe still need to be added. I'm just want to know if my cleanout and is ok or are there any other major issues with this setup. UPC BTW
Thanks
The second pipe in the wall is a 1.5 inch drain.
The pipe I want to go into is a 2 inch drain that is not being used.
To the right in the wall (next room over) there is a 1.5 inch vent that is just hanging there with nothing connected. Someone was going to put a laundry sink in there so there is some partial work done but I don't want a laundry sink in there so I removed water service.
It's hard to explain because it doesn't make sense. I can show you the back but again, it doesn't make sense what someone was thinking.
They came down with a 2 inch pipe and split it into a 2 in and 1.5 drain. There is a hole in the ceiling that looks like there was a 2 in (or plan for one but no pipe).
