Anorv120
Hello all. Hope you can help. We are doing some remodeling and part of that is installing a new washer drain box. There is a half bath right beside the laundry room so the plan is to tie into the existing drain and water lines. However, I have ran into some issues. First the cobbling of copper water lines is directly in the way of my proposed drain line, not a big deal I can rebuild it and keep it shorter and tight to the wall. Also, it looks like they left a 1/2 stub out of the slab for the toilet water supply but for some reason they chose not to use it and just T into the water supply mess for the sink instead? Should I see if there is water pressure to that stub and try to use it instead of the existing run? Thanks for the help.
However, this wall is a 2x4 wall and a load bearing wall. So, my question is can I use stud shoes for the 2" drain line and space the holes out for the other lines(1/2 water and 1.5" vent)? Is it even acceptable to use stud shoes through this many consecutive studs? Attaching some pictures of how it looks now and then a rough sketch of what I am trying to accomplish.
