I drew a quick schematic of my current main floor laundry plumbing situation (washer currently drains into a laundry sink) and a proposed situation to install a washer box a couple feet over.
In short, is the proposed routing acceptable?
Constraints: This wall is load bearing and is constructed with 2x4s. Also, the washer box needs to be placed in the wall void two 2x4s to the right of the current plumbing stack. Of course, I won’t be able to bore and run 2” plumbing through these two wall studs and attach the proposed standpipe to the current stack, so I figured routing new 2” plumbing directly into the basement and over to the current stack is a viable option while still meeting requirements for washer standpipe height, p-trap above floor, etc.
If this routing is acceptable, are there any other things to consider? I should be able to fit the p-trap and sanitary T between the two studs (it seems it will just meet code in this small space, with the 4” trap weir to stack measurement just being met, and running the 2” pipe above (reducing to 1.5” for venting) and below. Some other details/proposals are in the picture.
This is a visual of what I intend to achieve in the 2x4 wall cavity. I found it online and is just for reference.
I had a plumber come and quote installing a box, and as much as I believe he was worth every penny, the quote was outrageous. I’d rather keep the washer draining into the wash tub - haha. A second plumber came in a bit less costly, but he mentioned routing the 2” pvc in the wall through the studs. I didn’t entertain him for another second. At this point, I’ll gladly tackle the project myself, but want to make sure everything is done to code.
This is probably not important at the moment: I have also considered just installing the standpipe, plumbing for it, and washer box on the current wall instead of recessed in the wall, connecting it directly to the current stack. I’d still do some work to increase the stack in the wall and basement to 2” and reduce above to 1.5 for the current laundry sink. I intend to upgrade the laundry room and put counters over the front load washer, dryer, sink cabinet, cabinets, etc. Everything here would be hidden anyway. Shoot, after typing all of this, I’m now thinking about this option lol.
Thanks in advance! If there are any ideas, I’m all ears! Regardless of the best option, I want everything done right.
