Bucky Plumber
Hello,
A minor annoyance of my current water well pump system is the noise of a low steady vibration heard on the main floor and second floor of the house. It is not a knocking or clicking noise, just a steady, low vibration noise.
I am guessing it is the vibration from the pump system traveling through the copper piping into the wood foundation. I have tried to put rubber pads between the copper pipe and wood foundation where the copper pipe is mounted to the wood. This did not dampen the vibration at all.
My next thought is to remove a piece of the copper pipe on the main pipe (vertical piece show in picture) and insert something that will absorb the vibration. I was thinking possibly a 1" steel braided hose but am worried about restricting water flow through the main pipe and also what would happen when this line fails.
Any ideas or suggestions to help? Is there a piece that can be soldered in the main line to break the vibration?
Thanks in advance!
Thanks in advance!
