webmonk
- Joined
- May 23, 2018
- Messages
- 17
- Reaction score
- 2
Okay, I have searched A LOT for an answer to this sound. Problem is that people have a hard time putting a name to sounds and so when someone says their shower was "whistling", "squealing" or even "roaring" I may not classify mine the same way. Despite that I've tried a lot of the things I've found regarding any sound a shower makes to try and resolve my particular issue.
My Sound Problem:
What Has Been Done:
Note that the first sound you hear is when the water is diverted to the shower, keep listening. The other sound is the one I'm speaking of. I cropped out maybe 80 seconds between the two sounds.
Anyone have any other ideas?
My Sound Problem:
Where - This only happens on the second floor
House Type - two story house with a basement
Pressure Tank - yes, in the basement
Water Pressure - 50psi (reading on the tank and with a hydrant gauge)
When - It generally occurs within a minute or two of the shower starting
How Long - It typically runs for ten to forty seconds
How Often - Nearly every time a shower is taken... once it even happened twice in the same shower
What Has Been Done:
- First thing I did was to remove the shower head and clean out debris in the filter - Didn't fix the problem
- Second thing was to get a repair kit for the faucet valve - Didn't fix the problem
- Third thing was to soak the shower head in vinegar - Didn't fix the problem
WAV - https://drive.google.com/open?id=1addMBI7cyCDWOfHqni_4uo2Rp2UBrnhL
MP3 - https://drive.google.com/open?id=1yl-le1cPBOZZOKWFgN7wUPWnqpttyURW
