Hi, I have an internal, decorated drywall with poor studding: from left to right, there is a 22mm wide (i.e., horizontally parallel to the wall) stud, then a 38mm stud (the two studs are spaced 60cm), then the jack stud of the door.
I need to hang a ~2500 BTUs radiator (I have gas central heating), and I'd prefer to avoid both hanging on plasterboard and adding battens/noggins to fix the brackets.
So I thought to fit a vertical radiator (total width 27cm) by fixing all the four brackets to the 38mm stud via steel plates/flat brackets similar to this one:
Would that work and be doable?
Any suggestion welcome.
