watercamper
First post. Here goes. The roofers need to change the location of a pipe penetration through my roof. I THINK I can simply cut it off in the attic as I THINK it is just for a central vac exhaust. My question: Is this a plumbing vent stack or a central vac vent?
The pipe is EXACTLY 2" OD. It is not the 1 7/8" OD or 2 3/8" OD PVC that I can find at all of the stores in town. My house is piped for a central vac system. It was built in 1982.
I've attached 3 photos:
#1 shows the pipe coming horizontally out of the wall then turning vertical (I am in the attic). You can't see it in the photo but the horizontal part of the pipe turns vertically downward through a wall. On one side of the wall is a toilet. On the other side is the garage. However, right at this location in the wall in the garage is a 2" ID elbow for attaching a 2" OD pipe for attaching a central vac.
#2 shows the pipe going up through the roof.
#3 shows the exterior which looks nothing like my other roof penetrations which I believe to be plumbing vent stacks.
I attached my shop vac to the elbow in the garage and put it on discharge. I couldn't really feel any air coming out of the pipe up on the roof. I had to tape up the central vac ports in the house as air was coming out of them. This little test has me wondering if my thoughts are correct that this is part of the central vac system or is in fact, part of the plumbing system and should be plumbed correctly outside the attic. All help will be appreciated!
