hello. the pipe that goes from house through the roof, from my research it seems that it is called a vent pipe. well, this pipe has started leaking at the bottom (see image) when i run my dish washer. the dish washer is about 20 feet away from that location. my bathroom tub area also gurgles when i run my dish washer. the tub area is in a room behind that wall where you see the vent pipe. not sure if proximity is important but i thought i'd add this info. this is my immediate question. but also have other issues like the toilet where the tub is behind that wall, is not flushing properly any more. it drains slowly and water goes down, but it doesn't have any suction and/or pressure to flush. already changed the flushing kit with no improvement.
there is no sewer odor or any other unusual odor. there is another bathroom separated by one wall right next to that problem bathroom and things work just fine there. toilet flushes, no gurgling or any water drainage problems there.
by the time i took the picture the water has drained out and can't see it. when dishwasher is running, water continually and visibly spews out of that bottom part of the pipe.
thanks for your help.
