user 28607
- Joined
- Apr 21, 2022
- Messages
- 4
- Reaction score
- 0
Cannot find the answer to this precise situation so any advice would be very much appreciated, possibly more UK relevant as I'm not familiar with other countries specifics:
Our toilet cistern is fitted with separate fill and flush valves (both Fluidmaster now). There is no physical connection between the two valve units.
The fill valve works correctly and definitely does not overflow into the pan.
The problem is the flush valve (the third I have tried since discovering the fault):
Water very slowly seeps into the pan - at a rate that is quite difficult to see but has built up a trail of limescale from rim to water level over time.
I have read (and done) replacing seals & cleaning joints, hence why now on third valve unit. They are fitted according to manufacturers instructions, taking care not to overtighten which could distort the plastic fittings -(I'm told).
Here is where my situation is slightly different from all those I've seen posted online: the leak ONLY happens when the cistern is fitted onto the pan.
I have removed the cistern and placed it on a bench, supported above a mirror and old clear fish tank. I have then slowly filled the cistern with coloured water to various levels, up to but not over the top of the overflow tube. After an hour, there has been absolutely no leakage from the valve into the fish tank below.
As soon as the cistern is reconnected to the pan and even partially filled above the valve seal level, there is an instant leak of water into the pan.
The cistern simply sits upon the pan with the outlet end of the flush valve inside the doughnut seal (new as well) and is secured by two bolts.
Please advise if you've come across this too!
Thanks in advance.
Paul.
Thanks in advance.
Paul.
