Normally in all induced draft systems, with system off, we just suck on the switch and check to see if it actuates. We've heard of tubing deteriorating on furnaces but in over 20 years never seen a bad pressure switch on Navien and 50 years in HVAC not had but one bad pressure switch.Just making sure were on the same page, Im talking about the vacuum and vacuum line going from inducer assembly to the pressure sensor/switch. there is vacuum that/s applied onto the APS from the inducer motor. How can we know the right vacuum is being produced by the inducer motor
you can certainly use mouth to activate the switch during firing, or jump the switch at the right moment.
