Utility sink in unfinished basement
stevekr1
Jun 25, 2024
9
Delaware
DIY er here. We would like to install utility sink in our unfinished basement. No studs, just fiberglass insulation over concrete wall. We have access to water lines above, and I can bring pex behind the insulation. Will figure drain line later.
My question is what would be the best way to install stub outs.
Could I place a drop ear 90 on a 2x4 attached to the concrete and add a stub out to this?
Any suggestion appreciated
Drop ear 90 will work on the stud couple of bress nipples and ips stops, this way if the stops fail at some point you can just unthread and replace keep your water lines away from the cold area
If it’s just an unfinished basement I would just use a top fed laundry tub faucet
If you use a male adapter, or a brass nipple to stub out of the wall there will be male threads showing out of the wall then you can thread a chrome or brass stop on, making it easier to change if necessary ips= iron pipe size got it, then
If your dropping down onto the top of the sink and using that bracket, you would use copper and male adapters for stability
I'd be figuring the drain FIRST, not last. That is generally a bit more difficult than running PEX tubing.
I'd fasted a wood piece direct to the concrete, set into the fiberglass wall covering/insulation. Mount the sink to that. You could do similar for the supply lines from above.
Make sure about your wood connecting to your concrete,
PT or naturally durable wood is required unless the wood is separated from the concrete with an "impervious moisture barrier
Thanks, as far as the stop, I see mostly compression ones available.
Will that work on threaded nipple?.
What are the copper male adaptors you mentioned?
Appreciate your input
No compression works with copper , but you could use a male adapter and a piece of copper then your compression stop
Sorry, a little confused. So , a copper pipe attached to the male adaptor?
How does that get attached? Is it threaded?
I’m a newbie, so sorry for the questions
If I didn’t use a compression stop, what are the options?
