yeyildiz0 Member Supporting Member Joined Nov 9, 2023 Messages 19 Reaction score 1 Location MN Tuesday at 5:27 PM #1 Hi I am installing a kitchen sink by the wall and connect 4 4 1 1/2 wye or tee pipe to the 4 inch pipe in the image. Is this code? Attachments IMG_6526.jpeg 770.4 KB · Views: 0
GReynolds929 Professional Professional Joined Jun 16, 2018 Messages 825 Reaction score 428 Location WA Tuesday at 10:25 PM #2 Is there anything draining from above? If yes you need a separate vent.
M MicEd69 Well-Known Member Supporting Member Joined Dec 4, 2021 Messages 1,906 Reaction score 693 Location Missouri Wednesday at 10:24 AM #3 As that appears to be your main soil stack as there is a wye showing under the floor above, as GReynolds929 said, you need a separate vent. And you should indeed use a wye to connect to the 4". However, I would suggest using a 4x4x2 wye.
