(short lead in... had an addition build a couple years back and a Rheem ECO200 9.5 GPM tankless unit installed - addition is 1 bth, kitchen and laundry - with the anticipation of tying it into the main section at some point)
Question: what is the best practice to do so? Would it be best to run the hot side of the tankless directly into the cold side of the tank heater - thus feeding hot water into that unit or tee it into the hot side of the tank heater?
If you tee it in, does there need to be an isolator or check valve in line?
Thanks in adavance! -Bill
