For sure. Or at the least gunky.Are the bolts in the bottom of the tank on each side of the flapper rusted ?
A human can’t hear a drip from a toilet into the drain pipe below.It's just the extra fluid leveling out in your bowl. The bowl doesn't fill up and wait for you to flush, it slowly drains out to where its level with the top of the trap. You probably hearing fluid dripping into the drain pipe below.
I beg to differ, my toilet does the same thing and I can hear it. It's definatly a drip , somewhere between the inside trap down to the pipe below.A human can’t hear a drip from a toilet into the drain pipe below.
Well, then what are we hearing ? It's a water drip somewhere. If we can't hear the drip into the pipe, it must be internal to the water leaving the toilet somewhere. Nothing else it could be. Personally for mine I don't care, I can see the underside from the basement, and nothing going on there. So I hear a drip. It's not causing a problem so it's not bothersome to me. I just can sympathize with him as to what he hears.You don’t know what his toilets doing, you’re guessing and it’s a fact that a human can’t hear a drip under a toilet into the drain pipe not opinion.
That’s why I use dye to test toilets, because humans can’t hear that good.
Water movement from the tank to the bowl and water from the bowl rim jets and water ways leaking back into the bowl. The bowl is hollow. Water moves in this spaceI agree, water movement between the bowl and the pipe. You say I can't hear the pipe, maybe so, but it sure sounds like where it's coming from.
But dye wouldn't show that. Unless Im way off, that would show between tank and bowl. Not from the bowl out.... unless you take the pipe apart.
But what do I know, I'm just a DIYer, learning stuff all the time.
Yep, that is what some of the responders fail to understand that the tank has nothing to do with the sound based on the description sub1111 provided. Water movement from the tank to the bowl and water from the bowl rim jets and water ways leaking back into the bowl cannot be the issue.See, you taught me something. But just by adding a cup of water pouring directly into the bowl, and then hearing the drip, logicaly would point to the bowl water moving outward , adjusting the level in the bowl to be even with the top of the trap. Or so it would seem. Like the drips I drew in the picture
