OK. I hope I'm not breaking any rules or anything, being new to this forum.
I posted a week or so ago about the water level in my bowl. Well, after more research, the level is fine.
My real problem is it isn't flushing all the way.
Here is what I've tried so far:
1) I replaced the flapper (twice) and made sure the slack in the chain is not too much, nor too little.
2) I rodded with a toilet rod that I've had for some time.
3) I shut off the water, and poured about 3 gallons of water right down the bowl. I drained quickly. I soaked up the remainder so the bowl was dry. I then used tubing and CLR to clean out the holes under the lip from the inside. I them poked through them, carefully, from the outside. A couple were clogged badly, but I opened them. Still, same thing.
If there is a clog further down the pipe, would the water I poured in quickly have drained as fast as it did?
I just don't want to call someone out if there is still something I can check.
I appreciate any help.
Thank you.
Thank you.
