WhatIsThat
Hi everyone. New member here, in need of some help.
Finishing off an upstairs bath, and I've run into something that has me scratching my head. The plumber who did the rough plumbing left a toilet flange sitting by the waste pipe. I went to install it today, but a couple things seem to be a problem.
First is that the pipe isn't centered in the hole. It's sitting right against one edge. I can move the pipe just slightly, but not much. Will there be a problem in having the pipe resting against the edge of the subfloor?
The other thing is that the PVC pipe on the flange fits over the outside of the waste pipe. That just doesn't seem right. The outside edge of the waste pipe looks like it's been cut away, or gouged, so that there's a flat spot instead of it being perfectly round. But even if it were perfect, it just seems that the flange pipe should sit inside the drain, not out.
Any help would be appreciated!!
