newhomeowner68
So I bought this house (built in 1954) last summer and the toilet is a piece of crap (no pun intended). It's a low flow 1.6 G/flush by Eljer. The first problem I noticed is that when you flush it the water splashes out onto the back of the seat and lid if it's down. I noticed this little pink thing (see attached pic) inside the tank that is adjustable from 1-9 but I tried both extremes and cant figure out what it does, if anything.
The big problem is that whenever I take a decent sized dump the toilet gets clogged up requiring the use of a plunger and a few extra flushes. This happens about 50% of the time and even if I don't put any toilet paper in with the poo.
Also, my house is about 6' below street level and is equipped with a pump of some sort, maybe a sump pump. My two neighbors also have similar pumps as we are all at the end of the street that has a slight maybe 5-10% downward grade towards our homes. I was told that these pumps pump our waste water up to the main city sewer line at street level.
So I'm wondering if I have a crappy toilet or a crappy pump that's causing all these clog ups. Also, do these pumps need to be serviced and what would need to be done and how often? I remember the realtor said the previous owners "had the pump serviced by a plumber once a year". Any info would be greatly appreciated. I don't want to call the plumber because of course he's gonna want to come out to "service" it and probably charge me hundreds of dollars.
