Toilet clogged, Sink draining adds to water level in bowl
TDelaney
Oct 12, 2011
Santa Fe, New Mexico
Hi,
First time posting.
So, the problem is, my toilet is clogged, no amount of plunging seems to be doing the trick so I added some drain cleaner, waited, and when I went to add some hot water from the sink, I noticed that as water goes down the sink drain, it adds to the water level of the bowl.
I planned on going to pick up a toilet auger to give that a try, but was wondering if the sink draining to bowl thing would signify a specific problem.
*Maybe an important added detail is that my landlord always hires the cheapest labor and he has two "maintenance men" who seem to do the work on all of his properties and they always do the most amateur, half-assed work and probably put this bathroom together as it is a newer addition to the building, so I imagine this may be the root of the problem, though it has worked fine for a couple of years..
I appreciate any help I can get. Thanks.
You have a main line stoppage. No amount of plunging will solve your problem. The line needs to be snaked.
You should never put drain cleaners into a all-ready plugged line. Someone has to oped that line to clear the stoppage and take the chance of getting some serious burns from the drain cleaner.
John
