So I've got my DWV all assembled, I pumped up the balloon and filled it, and almost all of the test caps leaked.
I used the cheap thin little plastic caps that set inside of the pipe so that just the rim of the pipe is bonded to the cap.
I was a little suspicious when I glued them on, it seems like I'd need an absolutely perfect cut on the pipe to get these to effectively work.
I plan to get the caps that I can slip over the pipe and glue. I just wanted to see if anyone else had problems with these caps, or if I
used them in the wrong application, or installed them wrong.
Cheers,
Mark
Cheers,
Mark
