Pamenglish
Do you use teflon tape on pvc traps?
I use Rectorseal #5. As a matter of fact, I despise Teflon tape for anything, except the quick release fittings for my air tools.
The threads on tubular connections do not seal the joints from leakage. The tapered nylon washer ( type usually provided with the plastic and brass) is what seal the joint with the exception of the ground joint on the ell and J union of the p-trap. You should not have to use any paste or tape to seal these.
On the schedule 40 type p-traps I do put a little Teflon paste on the threads of the union to provide a little lubrication for easier assembly and dis-assembly.
I use Slic-Tite for PVC. It's the oil base in some paste sealants that is bad for PVC/ABS fittings.
