TBSE on a very long radiator
phloaw
Active Member
Jun 19, 2019
35
UK
I have a 225cm wide, 45cm high radiator on a standard vented, 8mm microbore two-pipe, fully pumped system.
I am getting rid of its old twin entry radiator valve to install a trv, so I need to decide where to position it and the lockshield.
Easiest option would be TBSE (top-bottom, same end) on the left side of the radiator, with a bleeding valve on the top right corner of the radiator.
However, intuitively, I imagine that with such a long radiator, even if the circuit is pumped, hot water could have a hard time getting from the left end to the right end of the radiator if both valves are on the left end.
Does this make sense, or TBSE will work nevertheless?
Thanks!
Your thinking correctly. You'd want the supply and return on different ends, and better yet different elevations. A vent on top to bleed the radiator.
You can do same end but there is a trick involving a double tap fitting and a dip tube type of injection pipe for the supply which actually is kind of better. It helps get more btu's out of the water.
Yes, previous setup had indeed a very long dip tube, but I'd rather save the hassle and go, as you suggested, for a TBOE.
Thanks!
