deporter
About 6 months ago I replaced a shower cartridge and ever since then I've noticed a change in water pressure throughout the house. Anytime we turn on a faucet there is an initial surge in pressure (no more than 3 seconds) and then it drops back down. I really notice it when our washer is on. You can hear the water surge and pipes shake in the kitchen even with the washer upstairs.
When I replaced the cartridge I ended up closing the water line from the street. I couldn't find a shutoff valve anywhere in the house. I looked under all the sinks, in the garage, closets, etc. and couldn't find it. There were two valve handles coming from the water main on the street that I closed and opened them once the project was done. There is also a pressure relief valve there.
Not sure if this is related or not, but our water heater had been dripping a lot of condensation out of the relief valve. I had a gallon bucket sitting underneath the pipe that would easily fill up in two days. We decided to replace it to see if it would help (it had just passed the 15 year mark). The new water heater still drips, but not nearly as much as the last one.
The water dispenser on our fridge also started dripping after the shower repair. Not sure if it's doing it because of the pressure or not, but something to take into consideration.
Lastly, I did buy a pressure gauge and hooked it up to an outdoor spigot. The pressure was at 60 initially and then dropped down between 50 and 55 after about 15 seconds. I left it on over night and checked it before using any water and it read 76.
Any thoughts?
Any thoughts?
