Sump Pump Discharge Line Questions
JuJo
Apr 2, 2022
Chicago
Thank you in advance for reading. I've had a rough time the past few months as my sump pump used to be connected to a sanitary line leaving my house but had to be rerouted when I had a plumbing issue occur and it needed to be brought up to code. I'll do my best to describe the new route (picture included). It goes up 7' to a 90 degree angle where it's tied to the floor joists. It travels approximately 35' then takes a 90 degree turn up and to the right. After a foot, it levels out and exits the house after a 45 degree connection. This new line has caused numerous problems.
First, the plumber routed it to a discharge line outside that ends with a bubbler that floods my yard and sidewalk.
Second, my pump runs constantly (every 2-4 minutes now that spring is here and up to every 45 seconds when it's raining).
Third, it is incredibly noisy. I replaced the check valve to a Zoeller quiet valve two months ago and it can only open about half way when the pump runs. I'm assuming it's because the line is so long and it basically has over 35' of water sitting on top of it. Every time it goes off it struggles to open and vibrates so loud that the floor actually rumbles upstairs. Also, it makes the classic banging sound (water hammer) every time the pump stops. As I mentioned, the valve is only two months old and it's already doing this. Finally, the line goes under my kid's bedrooms, so it's constantly splashing loudly. This is incredibly noticeable in the bedroom where the discharge line goes up and turns right to exit the house.
Luckily, because of the flooding in the yard, the city has approved for me to have the line tied to the dual storm / sanitary line that runs along my street. I'm hoping that will take care of some of the frequency issues because the water won't be recycling as much from my yard and back down to my basement. I am going to have that project done soon, but I had a few other thoughts on how I could reduce the frequency and noise. Please let me know if these are good ideas or not.
1. Raising the Pump: I was going to put some blocks down in the base of my pit (it's about 3' deep right now). I was hoping to raise the pump so that the float would go off when it was about an inch above the bottom of my drains. This way the drains would have to fill up about an inch before triggering the pump. I thought this would cut down the amount of times it would run each day.
2. Pitch: In order to relieve the check valve, should I pitch the line slightly so that all 35' of water doesn't come crashing back down on the valve? (The water would remain in the horizontal run) Or would that make things worse when the pump goes off and the new water smashes into the old water waiting in the pitched 35' run? I also thought about running the vertical run up into the floor joist on a 45 degree angle and then bringing it back down to another 45 degree angle before the long run. Again, this would prevent all of that water weight from coming back onto the check valve.
3. Second Check Valve: I also thought about placing a second check valve at the beginning of the horizontal run for the same reason -- to stop the water from coming back down on to the check valve on the vertical run. Or is this not a typical solution?
4. Hanging the Pipe: Currently, the plumber used J-hooks to strap the PVC to the joists. Should I used the hanging straps instead so the pipe is not touching the floor joists? Would this reduce the vibrations and noise?
I'm sorry about the long description. I hate to complain, but our new set up is awful and the noise is so ridiculous that something needs to be done. Any thoughts on my ideas would help. Thank you so much.
  • Sump Pump.pdf
    937.6 KB
The only pressure on your check valve is the vertical elevation between the highest point of the discharge line and the check valve. If it ran for a mile horizontally, the only pressure would be the 8 feet head you have. How old is the sump pump? The only issue I've had is with noise that you are describing is a bad pump. it looks like you added maybe 4-5 feet of head, which really shouldn't have caused any increase in pump noise.
DON'T raise the pump. That will not change the pump frequency of operation. It will only raise the water level under your basement floor.
If the noise is coming from the pipe, Isolate the pipe from any solid structure with a foam insulation and see if that helps.
Try to pipe your discharge to rise vertically to its highest point then let gravity drain the horizontal line once the pump cuts off.
This would cut some of your noise out when the check valve closes. It’ll also relieve some head pressure on the pump on start up.
Thank you for taking the time to read through my lengthy description.
I actually installed both the sump pump and check value in January. They are both new. When I lift up the lid to the pump, it's really quiet. Some of the noise comes from the valve. It struggles to open right away when I watch it and makes a "zzzzzzz" sound when it finally does.
The other noise comes from the water passing out of the house (when it has to go up and out) and the hammer at the end. It's significanly louder when I'm upstairs compared to when I'm in the basement. I'm going to start by separting the pipe from the joists a little and adding the foam insulation as recommended. There's just too strong of a vibration along the joists. Thank you for the recommendation.
Id love to pitch it down slightly, but at the end of the run it needs to go up, so there's always water in the vertical run.
Thanks again for adding to this.
A couple of questions. What is the depth and diameter of your sump?
The "zzzzzzzz" sound of the check valve struggling to get open could be caused by the increased head on the upstream side of the check valve. The normal practice is to install the check valve low as is reasonable to minimize the amount of water that flows back into the sump when the pump stops pumping. But your installation does have about 3 psi of water sitting on top of the check valve and a little over a gallon of water in that 7-foot vertical rise. That really shouldn't be a problem, but if your sump is 18" in diameter and 2 feet deep, it will hold over 20 gallons. So, if isolating the pipe from the joists doesn't work, you could try relocating the check valve to the top of the vertical run of pipe from the pump. That would put less than 0.5 PSI over the check valve, and less than 1 1/2 gallons of water is all that would run back into your sump.
Just a thought.
