user 33656
- Joined
- Mar 25, 2024
- Messages
- 2
- Reaction score
- 0
I had a new sump pump system installed many years ago for me. It has a main pump and a battery backup pump. I have a feeling now that the check valve is bad because the main pump is running way too often. When I went to check it, I noticed there is one on both the main pump and one on the battery backup pump screwed into the outlet of each. Instead of tearing out both check valves, would it be horrible to add a clear check valve in the main pipe coming out of the basin to see if that helps? I'm assuming they installed a check valve on each one so when one pump is running that it doesn't push water into the other pump.
