House is on crawlspace, just before the water main goes under the foundation, it tees of to feed the irrigation system, 9 sprinkler valves. The water is 75psi at an outside hose bibb which of course is after it come under house and supplies house plumbing. last fall I began having several leaks and problem with 2003 installed cpvc. I had a repipe done with worsbo PEX. Now I am hearing water hammer noises when the sprinkler valves close. When sprinklers are on pressure drops to about 40 at the hose bibb, and when sprinkler valve closes, spikes to about 110psi. I checked with a tell tale guage. I had a water hammer aresster installed but it did no good, still get water surge/spike. My question is , Would a pressure reducing valve set at 75psi stop the sudden surge from spiking from 40 to 110, or would that much water pressure surge just go through the PRV and still get the sudden surge??
