Stuck Bathroom Sink Drain Flange
Scott Braithwaite
Sep 18, 2019
Sacramento, California
Good morning/afternoon/evening,
In trying to install a new faucet we have encountered a stuck flange and cannot remove the old (1991) drain pipe.
We are using a socket wrench with various materials around the socket (electrical tape, non-slip rubber can opener grips, and even sunk a socket through a rubber stopper) pushed down into the flange while the other person holds the drain pipe.
Nothing is working. We're only getting slippage.
How might you folks go about this?
Thanks! :)
Scott
Just hacksaw off the drain part below the sink, after you lower the big retaining nut, then the sink flange will be free to lift away.
Or clamp a pair of vice grips onto the flange, then unscrew everything else from below.
Or bend all the edges of the sink drain flange upwards with a vice grip pliers, then it will drop down through the drain hole.
If you have a "Moto tool" type hand grinder you can use the cut-off disk to cut around the tube from the top (from inside the pipe). If you don't have one (very handy around the house) you can get a little cheepy one from Harbor Freight for under $10. Go in from the top just below the edge of the flange (the tube is very thin). Go around counter-clockwise so the disk doesn't catch, until the bottom tube drops off. ALL DONE!
image_27399.jpg $9.99
Do you mean oscillating tool? But that means that you must lay under the sink and cut over your face/eyes! With the Moto-tool and cutting disk you can cut it out from the top standing up. Cut about 1/2" down from the flange and cut counter clockwise. Should take about a minute.
