Mike_Lockwood
So we are not getting cold water in the shower. I read up on this and everything pointed to replacing the cartridge. Because of the age of the house we are unable to tell what type of fixture it is, my local plumbing supply store was able to determine the right cartridge by looking at the old one. So I installed it, Lasco 0-3213 and put it all back together. Turned it on and still basically no cold water, a trickle but it is still not right. I turned the water off, removed the cartridge and turned the water back on to see what was happening. Water was coming out but it seemed to be only hot, to confirm I turned the water off going to the hot water heater. Once that was done I was getting getting a soft trickle of water coming out. There seems to be another plastic piece that sits behind the cartridge but it is in there pretty good. Not sure if the cold water side has a clog or if there is something else going on. It should be noted that I have no issues with cold water anywhere else in the house.
