BRrenovator
Active Member
I installed a Delta R10000 PX Multichoice Universal Rough Valve Body with Pex crimp connections with universal outlets. I tested it after the installation and found leaks at the top outlet for the shower and at the bathtub stop on the bottom. My local plumnber advised me to use Oatey pipe compound in addition to the plumbers tape that I had used with the initial installation. I followed his advice, but the valve still leaks at the stop. Delta suggested that I take the compound off and double up on the tape. Since I've had this problem, I'd rather not take any chances and just solder the top and bottom connections closed. I've never soldered pipe before. Do you have any instructions on how to do this? Are there any other precautions?
http://www.deltafaucet.com/bath/details/r10000-px.html
Thanks
Thanks
