bob.smith
My refrigerator had water supply from a braided stainless steel line that was coming out of a hole in the wall behind the fridge and connected to the copper pipe somewhere in the floor between the first floor and basement. I installed a new water filter system at our kitchen sink and T'ed it off to supply filtered water to the fridge as well, and so I didn't need the existing line coming out of the wall anymore. The problem is that I have no access to wherever that braided line is connected to the copper pipe and no cap would fit the end of it, I tried various sizes. What I ended up doing is soldering the end of it sufficiently enough so that it was sealed close. That seems to have worked, but after the fact I realized that the solder I used was electrical solder and it contains lead. What I'm wondering is if there is any danger in that cap containing lead at the end of that braided supply line. Can any lead contaminant seep back into the main copper line from the end of that hose against the pressure? Also, is this even a viable long term solution or will the soldered cap eventually fail?
