am moving the master bath toilet about 6' from current location. unfortunately the connector for the existing flange elbow has about 3/4" of soil pipe before going into another connector which I have to keep, unless I want re-plumb the entire house. is there some connector like the rubber plumb quik that would take standard 3" soil pipe on one side and the other side a large enuf diameter to fit the od of a 3" connector?
I could take my dremmel and grind down the connector OD enuf so I can fit a plumb quik 3" to 3" connector, but sure if BI will allow that in sacramento ca.
some hearsay there is a tool that grinds out the inside of a connector to a tight enuf spec that I can glue new soil pipe right into the connector??? Any ideas appreciated, thanks
