kootenaybk
Hi... I own and live in a house in Western Canada. I think it was built in the early 60's. About 5 years ago we had our bathroom renovated. The sink was made by a local potter. Everything seemed fine for the first year or so. Eventually it (sink) started to drain slowly. When it would get bad enough, I would pour some Drano or something down it and it always seemed to help. The problem eventually would recur and I'd do the same thing. This time around, the Drano didn't seem to help so I called a plumber. The drain was snaked but it really didn't help. I was told there was no clog. He figured the problem was that this custom sink had no venting. A 'cheater' vent was installed just passed the trap. It still didn't help. Basically what I experience is that the sink drains very slowly. If the water is turned on slowly, the sink will fill and can take a couple of minutes to drain. If however, a stopper is placed and the sink is filled completely, then the stopper removed, it drains very quickly and really creates some suction. The plumber insists that there is nothing wrong and that it is simply a function of the sink shape, etc.. The problem I have with this explanation is that it worked fine for the first year or so. Something has changed. Finally to my question: can a (partially?) clogged main vent cause this type of problem? Any help is greatly appreciated.
