Then they are wrong. I have witnessed the effects first hand.
I agree with matt. A large amount of cold water is bad news for septic. They taught us that in school and i see no way it couldnt harm the system. Not to mention overworking your pump.
An 18-month research project has found that water softeners, when operated efficiently, do not harm septic systems or affect their ability to properly treat wastewater. The question has been raised for decades despite other studies that have had the same result.
If a water softener is set at an efficient salt setting, the impact on septic systems is very limited if any at all, says Pauli Undesser, director of regulatory and technical affairs for the Water Quality Association and foundation coordinator for the Water Quality Research Foundation, which funded the study. It was conducted by John Novak, Ph.D., P.E., through the Virginia Polytechnic Institute and State University with a steering committee consisting of the Water Quality Association, NOWRA, and NSF International, a global standards-setting organization.
and their you have it.
experience out trumps internet any day of the week
Thanks for all the input. The furnace is sitting on bricks, so its elevated a few inches. The water heater is just on the ground though. I will have to research local code. What does raising them do?
I will definitely look into insulating the duct work. The ducts also feed a few vents in the basement (it stays around 62-65, while the floor above we keep at 72), so its already intentionally 'losing' heat.
