javelindesign
Plumbing Pros,
I'm installing a PVC closet flange and am just wondering which of the two sets of openings to use on the flange. I think I once remember saying it was better to use the "non-sliding" (B in image below) openings because the plastic was thicker under them, but on my flange at least, the retaining plastic seems to be the same thickness on both.
I'm sure it doesn't really matter and either would be fine. I guess I'm leaning toward the "sliding" ones (A) since it will allow me to perfectly position the toilet?... then again, if I use the B set, it might be easier to drop the toilet on through the wax ring?
Just wondering what you pros usually do.
Thanks!
Thanks!
