Shut off valve cover/access
fleetmack
Nov 10, 2015
About 2 years ago the line between the meter (at the street) and our shut off valve broke underneath our yard. We had it replaced - they cut a hole in the wall in our basement, dug a hole by the street, and bored the new line in place by way of heavy machinery. 2 years later and we still haven't replaced the hole in the wall in our basement. It is unsightly, lets bugs in, and leaks cool air into the house, so we need it covered. However, this is the whole-home water shut-off valve, so it needs to be accessible. Issue is, the stairs turn to a platform and then turn right right in the middle of the hole and the shut off valve is in line with the platform - really a horrible spot for a shut off valve.
Anyways, attached is a picture. How would you cover this if you were me? I have seen those little door things at Home Depot, but the fact that the steps are in the way wouldn't let the door open up. (the hole extends below the platform just as much below as it can be seen extending above the platform in the picture). The shut off valve itself is about an inch below where you can see the copper line in the attached picture (in the square hole, the circular hole has a cover and is just a hose hookup shutoff valve).
Ideas?
Are you more worries about how it looks or how easy the job is? Personally I extend the shut off down and do a drywall repair and install an access panel under the platform out of sight. If you ever try to sell the house you don't want an eye sore sticking out like that. Just my opinion if matching the texture is doable for you.
If you don't care about the looks, something like a doogy door cover that slides in and out of a channel up and down could possibly work.
I'm not really worried about how it looks, it's a basement and we aren't high maintenance people. I'm not very handy though (I'm not a plumber). When you say extend the shut off valve, do you mean move it? That's a good idea - I'd have to hire someone to do it. If it's under the stairs I would care less how it works and could do full drywall repair above the step platform and do some ugly easy-access door down below, that would be cool.
How much would a plumber charge (approx - $100?) to move the shut off valve lower?
