I’m installing a new dishwasher, and spent several hours researching, but can't find out a few key things. I discovered this site a week ago, and I've joined as a premium member with this as my first post. The condo builder 20 years ago left a 24”w space under a counter by the sink for future dishwashers. The rear wall has a water inlet metal stub, electric outlet and a 1.5” PVC drain stub. The stubs are about 8” above the floor, and stick out 2-3”. I bought in July and I’m pretty sure a dishwasher was never put here. The drain stub was covered with duct tape, which I removed to view. I don’t have a garbage disposal and never plan to have one. It seems like my two drainage options are either:
A) Connect to the sink drain. I don’t like this due to the drawbacks of: I’d have to drill a hole through the cabinet, it would expose my sink cabinet to another leak point, and I’d need to find a branch tailpiece that fits with my existing double-bowl set-up (see photo below) … and install it. It would also mean a longer hose length, but does it matter whether a hose is 7’ versus 10”?
B) Connect to the drain stub. I have concrete walls in and out. In the wall, the 1.5” pipe right angles straight down at least five inches after the bend. I poked a flexible inlet hose in, and several inches of it continued down past the turn without hitting anything. My questions about approach B are:
1) I don’t know what the drain stub connects to or how far down it connects. Does that matter, and if yes, what’s the possible issue? I’ve read a lot about having a high loop. If I put a high loop behind the dishwasher, would that be enough to avoid issues with using the unused stub? For example, does the dishwasher drain flow need a p-trap somewhere along the way?
2) The owner’s manual says: “Make sure to connect drain hose to waste tee or disposer inlet above drain trap in house plumbing and 20" (508 mm) minimum above the floor.” Do you think that only applies if I’m connecting to my existing sink plumbing … or would it also apply to connecting to the unused drain stub? If it applies to the drain stub, is it workable to install a drain tee onto the stub?
The manual also says: “It is recommended that the drain hose either be looped up and securely fastened to the underside of the counter or be connected to an air gap. Make sure to use an air gap if the drain hose is connected to house plumbing lower than 20" (508 mm) above subfloor or floor.” Do you think the last sentence is only referring to a situation in which I connect to the sink plumbing? Or does it also apply to the unused drain stub? The stub is only 8” above the floor, not 20”.
So far I haven’t been able to find an adaptor or connector to transition from a dishwasher 3/4” drain hose to the 1.5” stub out, which is about 1.8”w on the outside. Does such a product exist and what is it usually called? The first photo below shows the stub outs. The second photo shows the nearby sink plumbing.
I’d prefer to use the stub out drain, but I definitely don’t want to install an air gap. So if an air grap would be essential for using the unused stub out, I think I’d sooner settle for having the drawbacks of connecting to the sink drain. I'd really appreciate any and all advice. Pete
