Shall I take a look at my BW anode rod myself?
Thank you for the PDF attachment. It appears that PVC is approved for those power vent models. I stand corrected.....
.... I will now crawl back under my rock.
Model # appears to be MIITW40S5CN10 (but I didn't find any exact match at the document center over at B/W website).
My opinion is that you already have what appears to be a very old water heater. I see no way you could even view the anode rod without cutting your hot water side and removing it. If you are going to that extent, I personally would replace with a new model, which is going to last you well into the next decade.
Interesting—so on these types of water heaters where the anode rod is in combination with the hot water outlet fitting—we're not meant to check it and replace it DIY you're saying.
