Sewer Leak Mystery/ Cast Iron Pipes
tedpenn
Oct 22, 2015
Nashville, TN
Hi,
I have a house built in '63 with old cast iron pipes. The kitchen drain line (covers sink w/ disposal and dishwasher) stops up about once a quarter, resulting in many, many plumber visits since 2006. Additionally, I have a mysterious, intermittent, sewage leak directly below the kitchen in the basement, which seemingly comes from ground level, underneath the baseboard, near where the chase for the vertical drain pipe runs.
Of all the plumbers I've had come snake the sink and try to diagnose the problem in the basement, none have been able to give me a definitive answer on where the problem is. They all want to just start replacing pipes (which I'm sure is where we're headed eventually), but they all have a different idea about how MUCH pipe to replace, and HOW to replace them (replace what's in the chase, vs. run new pipe in a new chase, vs. run new pipe outside), etc.
Here's where things get tricky: My drain pipes run across my yard, right by a tree, and then down a rocky hill and across a field about 400 feet before joining the sewer main. My problems could be due to old cast iron pipes crumbling, build up inside them, root encroachment (the snakes have pulled back what looks like tiny roots in the past), or some other problem I'm not even aware of yet. Before I go to the expense (and huge inconvenience) of busting open walls, digging up my yard, and replacing sections of pipe, I want to be absolutely positive where the problem is.
Here are the questions I have:
1. As far as I know, a video snake inspection is the only way to be sure where the problem is. Is that even possible with my old cast iron pipes which may be blocked or crumbling? Is there another method that would reveal where the problem is for sure?
2. My pipes are PVC in the kitchen, which joins a cast iron vertical section going downstairs, and then (I think) over horizontally in the concrete slab or right outside in the ground, then away from the house down into the field. If I start replacing pipes, what is the best way to do so? Replace what's there in the existing chase and slab/ground? Leave the old ones and box in the new pipes in new chases? Run them outside the house?
3.How screwed am I given the age of the pipes and that they're cast iron or clay (the pipes outside may convert to clay at some point; I'm not sure.)? Am I looking at eventually replacing ALL of the pipes all the way to the mains? If so, I'm assuming I'd have to install a new trench with new pipes, and somehow get down the eroding rocky hill (a small section of the old pipes is already exposed out there due to erosion). I assume doing all that would be very expensive and involve tearing up the yard to the point where I might have to rethink/re-landscape the back yard and hill.
Any advice you can offer is greatly appreciated. I hope I've explained clearly; let me know if pictures would help clarify. Thanks!
Ted
you have roots growing in the old pipes.
it all boils down to money..do you pay a plumber 4 times a year. $300.00 each time to snake it
at $1200.00 per year. wasted money
or do you get off of your wallet and have the sewer replaced.
my opinion on your sewer, with out looking. just from experience
****s 50 years old, cracked, full of roots. replace it from the city tap to the house.
now, the sink drain, replace ALL of the drains. leave the vents
  • Like
Reactions: SHR
Hi, and thanks for the response. Can you answer either of the first two questions I asked? Also, would you have any idea off the top of your head what I might expect to pay to replace all 400+ feet of sewer, given that at least 15 feet or so of it runs down a rocky hill? I'm assuming we're talking heavy equipment and serious money to do so but I've never had to do anything of the sort so I have no idea.
Thanks!
Hi,
1. As far as I know, a video snake inspection is the only way to be sure where the problem is. Is that even possible with my old cast iron pipes which may be blocked or crumbling? Is there another method that would reveal where the problem is for sure? NO
Post pictures of the piping
Ted
what it would cost? i have no idea, different pricing from town to town, state to state
i have no idea of parts pricing, equipment or labor costs for your area
call a couple of local plumbers for quotes
  • Like
Reactions: SHR
Answer to question #2: No mystery. Your old steel pipes have finally rotted through. Open wall behind sink and replace all of the steel drain pipe with PVC. Sooner the better. I agree with Frodo on leaving the vents, I always leave the vents unless there is an overriding factor in isolated cases.
Last year I replaced the drain piping in walls behind the kitchen sinks in all 48 units of an apartment complex I do alot of work for. Most either had leaks or I was able to poke holes in the existing pipe with a screwdriver or pliers. Landlord is very tight with $$$ but even he could not put up with sewer water leaking in the walls.
If the pipes run down into the concrete slab, what is the best way to replace those? Will they have to be run another way?
