arrkerr
I have a sewage ejector in my basement that ejects a sink, toilet, and shower. It pumps up about 10 feet to join in the ground-level pipe to the septic tank. The house was built in 2004, and presumably this was installed by the builder at that time, although it may have been put in later by the previous owner when the basement was finished. It appears to be done correctly - vented, etc.
The problem is that every time the pump turns on, once it turns off there is a huge THUNK. I'm pretty sure it is the force of the water hitting the check valve. The check valve is about a foot on top of the tank, so about 9 feet from the sewer line it connects in to.
Eventually after enough of those THUNKs, the hose clamps on the rubber connectors between the PVC pipe and check valve will loosen up and high-pressure sewage will shoot out all over the room, which is a nasty thing to clean up!
The pipes run up the middle of a small closet-sized room, so I can't easily attach them to something solid to prevent the thunk. I can possibly secure them better in the ceiling. If I had to, I could run a 2x4 down from the ceiling to the floor and attach it.
I haven't found any code or guidelines on this. Any suggestions would be much appreciated.
I can post a picture if that helps.
Thanks!
Thanks!
