- Joined
- Sep 28, 2014
- Messages
- 8,578
- Reaction score
- 2,977
that is the problem. your set up works when the pipe is under the crust,,,but when the crust gets into the pipe
it will stop it up
it will stop it up
UPDATE #2
Kinked up a 50' snake, gotta get a new one. While I'm at the LHS, I'll score some Rid X.
Plan
1. liberally apply Rid X directly into the full tank
2. Snake the laundry line and hopefully restore toilet function
3. Get tank pumped on Monday
4. Have the septic guy install a new baffle (or do so myself)
Thoughts?
/ thanks to everyone who's responded. This has been a really poopy job thus far
install a cleanout on both sides of the tank
using 2 wyes and 2 45's per clean out set up
I wonder if a riser kit is available for a D-Box (or if one can be bought that way)? Easier than locating and digging.
All tanks and Dbox lids should be above ground to prevent infiltration of ground water.
Like I said. No one should DIY a septic system. I hope the OP knows that everything needs to go through proper permits and such. I have seen some hacked and cause illness among other things.
...the baffle not being there doesn't bode well.
Question: if I were able to dig up the field myself (*doubtful), could the gravel in the trenches be reused? I am capable of installing the pipes.
*ground here is hard as concrete
Anyway - I think I know what caused the leach field failure.
First, as a family of 5, I am positive that we over-stressed the system. On the weekend of Nov 4 we got 8" of rain in out area. That is pretty well unheard of 'round here. It rained heavy for 3 days in a 4-day period. I think between our heavy use of the system and that much rain, that the drain field simply got over-loaded and took this long to right itself.
Does any of that make sense?
Plan to.Please keep the board informed (via this thread) as it is a learning experience for all.
I rerouted the washer line about 2 weeks ago. Runs out into the yard now (legal in NM).If possible, "daylight" or drywell your washing machine. Also one thing you may not already know. It is really bad for a septic system to sit for a long period of time when not in use. Lines dry up and deteriorate etc.
Need something to break up that grease.
http://www.lenzyme.com/Grease_Education_Clearing_the_F.html
something like this
Water jetting didn't really seem to work.
Need a suggestion for an auger head that will work on a 4" pipe
If the jetting didn't work then you have more going on. For augering or jetting to be effective at removing grease you must be able to establish flow so as grease breaks up it can flow away. Properly done jetting should have been able to pull grease back out of line rather than flushing it to leach bed. It might be time to call in a professional, rather than trying to auger this and flushing grease into leach lines.
