1. Septic Tank periodically overflows through the inspection ports (seems to be mainly the inlet side)
2. ALL house drains/lines periodically back up and snaking appears to help alleviate the problem for a few days
Tank was pumped about 5 or 6 weeks ago, no drain backup was noted at the time. Now the laundry room line needs to be snaked every 3-4 days and standing water appears above the tank regularly. We are a family of 5 and I know we're putting 100-150 gallons of water down the drain lines every day. Washer drain line is separate and doesn't go to the tank.
Basically - where's the clog?
This map isn't to scale.
I can get 50' of auger down the laundry room line and that definitely makes it to the main T-out - but which way does it go from there? I mean, does it turn out the septic or go on towards the main bath line?
I'm at a loss here. Pumping the tank is not cheap (we live in the boonies), should I head to Home Depot and invest in different auger cutter tips? Like I said, running the snake a few times tends to clear the lines for a few days, but the problem always comes back.
Thanks in advance for any help.
-Jonathan
-Jonathan
