Sandblasting Water Pipes
StrongEagle
Active Member
Dec 29, 2013
30
Houston, Texas
I've run up on a couple of companies that offer a service to rejuvenate old water pipes.
They remove fixtures and faucets, then use compressed air to drive an abrasive material through the pipes, cleaning out rust and scale. Then they blow through an epoxy resin to permanently seal the pipe.
I know a fellow who described a small apartment building that successfully had this done, at far less cost than pipe replacement.
Is anyone familiar with this for residential applications in Houston. Here are a couple of links to companies offering such service... I am not in any way affiliated or advertising... offering these links for a more detailed description of the process.
TIA
http://pipe-shield.com/#problem
http://www.aceduraflo.com/company/about
We used to service a property that had a central hot water system for that was constantly plagued with slab leaks. They had the hot system coated with epoxy. I heard that it has failed on several occasions. The problem with failure is now you have to repair a section of pipe with a coating inside it.
Once it is repaired, how do you recoat that repair? you can't. So now that epoxy can flake and peel off causing all kinds of other problems.
I don't have any 1st hand experience with it but I hear it has problems and pipe still ends up leaking. Sometimes in less than a year after installation
It's to hard to get the inside of the pipe clean enough to get epoxy to properly adhere to it. There is just no way to get every bit of rust and scale out.
And the little guy crawling up in the pipes need really small paint brushes. I bet they are expensive! ;)
