Rusted pipe connections only
Jgaro
Jan 13, 2016
Hi all,
In the picture attached, you can see that I have a handful of rusty connections only in the joints of the pipe coming off of my hot water heater. Any thoughts on whether this should be addressed proactively and why?
Thanks!
More pictures attached. Not sure which valve you are referring to. The one going into the heater looks fine. All connections on the exit side and beyond are rusted on joints only.
If you wanted it to look nice sure go ahead and replace it but other than that no need.
...mmm...
attachment.php
Galvanized should not be used for gas . Black iron should not be used for water .
God bless
Wyr
The pipe is typically coated. The fittings are just oiled. This is normal. If you are worried how it looks you can brush it off and give it a coat of paint.
upc 1210.1
Gas Piping
1.Metal gas pipes buried in ground shall have minimum 12" cover and be factory wrapped. UPC 1211.5.
2.Plastic gas pipes shall have min. 18" cover and shall also have #18 AWG tracer attached. UPC 1211.16
3.Gas pipes shall not be directly embedded in concrete or underslabs. UPC 1211.3.
Exception: When necessary due to structural conditions and with prior Administrative Authority concurrence, approved type gas piping may be installed under slabs (i.e. gas pipe in special sleeves (conduits) or accessible trenches (channels). See sketch for options.
4.Gas ferrous metals pipes shall be factory wrapped. 609.3.1.
5.Gas Testing: 10 psi. (6" of mercury) for 15 minutes. UPC 1204.3.2.
6.Gas piping material: Wrought iron, steel (galvanized or black) or yellow brass. UPC 1210.1.
7.Gas piping shall be polyethylene pipe only for exterior-bury conditions. UPC 1210.1.
8.Buried galvanized pipe shall have factory-wrap. UPC 1211.3.
9.Exposed gas piping shall be installed 6" above ground. UPC 1211.3.
10.Gas Connections: Shutoff valves shall be less than 3 ft. from the appliance on supply side of union. UPC 1211.15. Gas Appliance Shut-Off
11.Gas Piping Sizing Work Sheet per UPC, Table 12-3 & section 1217. Go!
God bless
Wyr
Except steam and condensate are run in black pipe . As are chill water and condenser water .
That is the way they do it here .
God bless
Wyr
