A self-feed bit is a much better choice.If you are concerned about the splintering a spade bit will create, suggest you implement a "backer" board behind each joist you drill.
Appreciate the info but still a little confused about which direction we are talking about.The 2" from edge of hole to top and bottom is an established guide. The 2" from edge of hole to edge of hole I mentioned above is to provide adequate support between the top and bottom of the joist. I simply doubled that to determine the 4" edge to edge as a safety factor based on non-smooth hole.
There is a question that is often asked of engineering students. "What is the purpose of the web in an I-beam?" The answer is, "To keep the upper and lower flanges apart." In other words, the strength of an I-beam is based on the top and bottom flanges. Translating that to a joist. as long as you can keep the integrity of the top and bottom areas of the joist intact, and the center part of the 2x6 such that it maintains the separation of the top and bottom areas of the joist, you are good.
Sorry, can you explain what you mean by "implement backer board"? Do you just mean attach another piece of board behind the joist that I am going to drill through? If so, should it be screwed in or just clamped and is it permanent or temporary?A self-feed bit is a much better choice.
clamping a scrap board/whatever is all that is required. That board will afford splinter free holes for the joists.Sorry, can you explain what you mean by "implement backer board"? Do you just mean attach another piece of board behind the joist that I am going to drill through? If so, should it be screwed in or just clamped and is it permanent or temporary?
On the topic of reinforcement though, I asked previously but got no response:
Can anyone weigh in on if that is a good idea and how many / where you would suggest installing them on the joist? One per hole, a sandwhich per hole, etc?
- I was wondering if applying 12" mending plates / straps to the joists would be a good idea? If so, any advice on how to apply them in terms of how many, location, etc? Should I put one on each side to sandwhich the joist - or one on top only or on just one side? Does top vs bottom matter?
I understand that I need 2" from the top of the beam to the bottom of the beam and thus should drill the hole in the middle of the 2x6 (so center at roughly 2.75").
Beyond that though, I also am concerned about how far further down the board (as I need to drill holes for 2-3 holes) I can drill another hole which I read your response as saying 4" - did I understand you correctly? If so, I then was curious on if there was any specific reason the horizontal movement required 4 vs 2 or just a gut feel sort of deal.
As to reinforcement, I answered that in #4. But now knowing your actual conditions, I would simply drill the holes with a self-feed bit of the appropriate size and leave 3" or 4" of wood between the holes without any reinforcement required.
Ok, fair enough - thanks!Yes, I would custom make them if I thought they were needed as I don't know of any "off the shelf" items that would work. But as I said, based on the details you've provided, reinforcement for the holes you are planning is not required as long as you meet the dimensions restrictions noted above.
