I can’t get rid of code 63 on my hybrid Rinnai heater. The code keeps coming back intermittently. The manual says to (1) clean water filter, (2) check the water flaw and/or (3) clean the heat exchanger. I’ve cleaned the water filter twice - and the second time the filter was clean so it was not the filter. I don’t know for sure what heat exchanger is but I assumed after some research they mean flushing it with vinegar. Am I correct? Either way, I did that twice for around an hour each. I don’t know how to check the water flow but I think you’ve got to press some button combination for the water flow to display. However, let’s say the water flow is low, what would I do next? Also, why would water flow become low all of a sudden? Is it possible the flow sensor is bad?
I’m assuming, this is what’s happening: when a shower is extra long, you use the water in the tank first. Since the tank is only about 20 gallons, at the end the heater switches to tankless. This is when it goes to the code 63. So the issue is somewhere in the tankless part of the heater.
Any advise is greatly appreciated!
Thanks
Thanks
