Helped my son get his atmospheric vent Rheem natural gas water heater going after it failed. It turned out to be that the TRD device exploded, I guess as it is intended to do if there is an over temperature in the burner area. Found a replacement and managed to get it back in place. However when it started up again the flame was fluffy and orange/yellow instead of blue. The vent seemed to be drawing fine on the exhaust. There seemed to be no obstruction of the fresh air supply to the heater. The vent outside did not have an ice build up.
While we were standing there discussing what to do about it, the flame all of a sudden turned blue and looked just fine. It seems to me that the poor combustion was the likely cause of the safety device failing as it should under high temperature (500 deg).
Any thoughts what may be causing the poor flame and why it would clear itself up suddenly? I looked at the gas orifice on the burner when it was out and it looked fine?
