Had a few questions. My house is about 65 years old and has galvanized water supply lines. Loosing pressure and crap breaking loose in the pipes is causing pressure drops. I have a 5/8" meter and the original supply from line 3/4 inch where it splits to feed water heater and rest of house. At the split it drops to 1/2" to feed water heater and the rest of the house. Outlets for fixtures are 3/8". Looking to replace everything with PEX. Thinking of doing 1" from meter to manifold where cold would have a loop for the supply. There are 2 outside hose bibs that would come off the manifold with 3/4" and a 3/4" to feed water heater. The hose bibs would get reduced to 1/2" before connecting. My thought was to run a separate 1/2" line for each fixture, kitchen faucet, dishwasher, bathroom sink, shower, washer, etc.. and then either make the stop valves 1/2" or 3/8". Run 3/4" PEX from water heater to manifold and then run to each fixture in 1/2", stop valve in 1/2" or 3/8" to match cold.
Two major questions, Waste of time to run 1" from meter to cold water manifold loop?
What size is advisable for fixtures, shower is currently in copper and 1/2" to fixture.
Want to get to where more than one fixture can be ran without loosing water pressure.
