I'm looking to replace the stack in my basement... I unfortunately can't just call in a pro right now, too many things going on and I'm just looking to replace with PVC, not really redesign/reinvent the wheel! Here are my questions and open to any concerns someone here with experience may have:
The main reason I'm doing this is I discovered the top 4" cast is completely cracked the entire length on the top side (my guess is it wasn't supported properly? not sure why).
My plan of attack:
Cut the 4" cast between the cesspool exit and the main cleanout trap, connect to new 4" PVC there with a fernco and build out PCV from there including a new 4" PVC for that vent as well in the same location in the trap (first).
The 4" cracked toilet drain, I'm going to carefully try and chisel/break the hub off the elbow sitting on the foundation, and fernco 4" to PVC there. otherwise going to use a sawzall and cut it before the hub. The elbow seems to be in good shape.
and last cut, 2" shower/sink drain before that hub there above the gas line (ya I'll turn off the gas) and 2" fernco to the new PVC stack 4x4x2 whye.
If anyone has some time before I attempt this weekend, please feel free to share your concerns/suggestions. Anything not mentioned is just going to be plumbed as is using PVC
Thanks!
My plan of attack:
Thanks!
